1951 reo m35 or m59 brake issue.
Mackafd
Walnutport pa
I just picked up a 1951 reo m35 or m59. the owner put a regulator on the air system to lower the psi going to the air pac down to 60psi. he says any more then 60 and the brakes lock up?? this is a new airpac anyone have any ideas???
gimpyrobb
dumpsterlandingfromorbit!
27,787
778
Cincy Ohio
That sounds very wrong. I guess its time to pull the hubs and see what needs fixed. Sounds to me like you might need new pads or if your lucky alignment pins.
1,824
That is a faulty airpack regardless of age. Now, if they start applying after a few stops, that could be other items. If you crank the air above 60 and the brakes apply themselves, that is airpack for sure.
Mackafd
Walnutport pa
Ok when I was at the truck yesterday I pulled a sample of brake fluid and placed in a jar it was amber. Then added a little water and got instant milk. Shake it and left for over an HR and still had milk. Now he said he thinks he used dot 3 when he did the wheel cyl and master and installed a new air pak so I think I am good to say continue to use dot 3.
1,824
Considering that I would clear all the fluid in the MC and powerbleed/flush the system.
NDT
7,348
Camp Wood/LC, TX
Unless the truck recently came from the military or the owner has done a high quality restoration on it, the brake fluid will be DOT 3.
Karl kostman
922
Fargo ND
MILKY???I have never had that experience when testing brake fluid! What you should get is after you shake it up and let it sit you should get a defined layer of water and a other layer of brake fluid, I have never seen anything MILKY in my test jar? Like recovery4x4 said I would drain and flush the brake system then refill with fresh DOT 3, yes I know its a little more work BUT then you know exactly what your dealing with!
Karl
topo
279
farmington NM
Looks like water on bottom and something on top ? Not knowing anything about this truck I would check all fluids for water and look at the wheel bearings .
