1955 curtis wright m35?
1,823
Most everythint Lindsey. If the Curtiss Wright is a gasser then that stuff will be different as will the tranny. Gasser front fenders are different but can be used if need be. Any thoughts on what you would like to swap to the M35?
bigmech
Potterville Mi 48813
THanks for the info. It is a gasser and seems to be in great shape. It is a water tanker that a local fire dept had. I need a radiator and would also like to convert my shorty m35 into a all wheel steer! I don't have to use anything if somebody wants it. I'm the high bidder and it looks like evryone else thinks it scrap. It is very clean and straight and was driven two months ago according to the caretaker. If I win it do you know of a radiator for swapping material . I can't believe that it would fit mine, but there has been a few things I can't believe that still happen with these cool trucks.Will the front axle be the same as my m35?
1,823
Front axle to be the same with the exception that it might have a different style axle joint. . Was the tank added or is it an original tank? The truck sounds interesting.
lacoda56
Rochester, Washington
I'd kinda hate to see a another complete deuce cut up for parts when there's so many parts units around. Radiators can be found but 51 year old trucks are getting harder to find every day. I know ya can't save em all, but that's that's the way an old fart see's it.
DDoyle
West Tennessee
While I firmly believe that when one buys an object, its their's to do with as they will, but I tend to be with you on this lacoda56 - try to find a gasser - all stock - much harder than one would think. Even tougher, an unadulterated M35A1.
Regards,
David Doyle
bigmech
It was on the gsa auction and I got sniped I was trying to steal it for $400, man being cheap doesn't always pay off. I don't know if the tank was an add on or not the guy that answers questions was short on the other ytrucks I had to ask about and cut me off after 10 minutes. I did get a M50A2 at least thats what was listed . It sure looks like a M35 with a side trop bed that was added. THe bed looks to be differently painted and newer, so I guess it could be possible. anyway it has a trans with a couple of gears that don't work so I won that . I figured the engine had to be good if they said the trans isn't. I will probably use it for parts to finish my two trucks. Sorry if that makes a few sick . but money is still money! I did get a 1983 chevy 2 wheel drive diesel pick up with a 4 speed that runs good. I'm going to sell that to pay for the trip to pick up the duece.
ida34
35
Dexter, MI
I was looking at those two but with Christmas coming up I could not partake. I also did not want to travel to Gaylord to get them.
