1985 AM General M923 Question,
SPC_romaine
Greenville SC
I was wondering if you guys have any idea if this has air brakes or not Im looking at it on Government Liquidation but they dont list if it is or not I seen one on a diffrent lot but I wasent sure wether it was for that one or not, Because on the back I seen like it has the huck up for were you can pull a trailer with air brakes. But Not sure. Would think they had air brakes in 1985 but I could be wrong " got to work on History :p "
Nonotagain
Parkville, MD
To answer your question, all of the 900 series trucks have full air brakes.
Depending on your states requirements, you may be required to have a class B drivers license with an air brake endorsement.
jasonjc
291
Gravette Ar.
Really I did not know that HMMWV's (M998's) had air brakes.?.?.:?
Or did you mean to say all M939 series trucks??
SPC_romaine
Greenville SC
Thanks I'm trying to find out if in SC if I can get a class E or F will cover the air brakes because it's not over 26,000 lbs when I look it up it says a can go over 26,000lbs with a truck and motor home and the wheel vichle so I don't fully understand it any idea cuz SC don't do airbrakes odd on's for driver linc... We have the different class dlso I have no idea lol
Bighurt
46
Minot, ND
Most states now have air brakes as an endorsement a written test is all that's required.
South Carolina requires an Air Brake skills exam...
porkysplace
1,496
mid- michigan
Michigan requires a written and road test for the air brake endorsment .
Every state is different contact your local DMV or what ever they call it in your state , and get the rules from them .The need for a endorsment usually goes by the GVWR not the actual weight of the truck .
Bighurt
46
Minot, ND
Hence the word "MOST"...not "ALL"...your mileage may differ...
SPC_romaine
Greenville SC
o ok ill give that a try and see what they say, on monday. thanks guys.. Just trying to get every thing right before i start bidding and then get stuck in some way.
