1986 AM General - engine question
Ashes
Abingdon, VA
Hi folks! New to the community here. I must say, WOW what a wealth of info.
In a couple weeks I will be going to inspect and hopefully pickup a Deuce at Fort Pickett for my Fire Department. The only info I received so far is the truck is a 1986 AM General, super singles, no winch and it has a Cummins 250. I should be getting more info over the next week.
My first of many questions; Did deuces come with a Cummins 250? I thought this was a 5 ton engine.
Thanks!
1,164
The NHC 250 is an M809 series 5 ton engine, so one of 2 different scenarios exist:
Your new truck is a 5 ton
or
Your new truck is a deuce and you received erroneous info.
Ashes
Abingdon, VA
Thanks for the quick replies. We plan on going up on the 10th of December. I will document the trip with photos and the mild transformation we will do to the truck once we get it to the station.
Thanks :p
wreckerman893
Possum Connoisseur
15,647
2,141
I spent 34 years in the Army and can say with certainty:
There is no way to get a 250 Cummins in a deuce.....well not any practical way....too big, too heavy, needs a huge radiator, sheet metal would not work, yada, yada, yada.....I concur with Clinto.
91W350
60
Salina, Kansas
I am not so sure wreckerman, I think we might be able to stack three or four in the bed of a deuce. A few 250s should do a great job of slowing down the rear tire slippage. :p
D
Deleted member 11142
Guest
if its a 1986, couldnt it also be a 900 series?
