1990 M923A2 trans filter
Big923
Owings Maryland
Hey everyone just got my first MV, a 1990 M923A2 and am looking for any tips tricks or advice, and in this case an answer to a specific question. I want to get the motor oil out of the trans and get good fluid in it. I know I need to do a double flush, and replace all filters. My question is which filter do I need to the pan and how to I change it? I saw another member post about a NAPA #1892 kit for is A1, will this be the same for my A2? And which fluid is best to use? Also I plan on taking this vehicle 1500 miles from Maryland to Kansas in a couple months, what all would you suggest I check/replace before undertaking this endeavor? Thanks in advance!
MuleMac01
Military vehicle collector
187
Las Vegas Nevada
All the M939's transmissions are almost the same thing so use the Napa pan filter just like I did it comes with a gasket your going to need it.. Second the fluid question has been asked countless times Allison would have you put there best stuff in (transynd). You can use dex 3 or and 10wt oil with a Allison C-4 rating also some people use 15W-40 in there's. To remove the pan filer drain the pan, remove the pan ( your going to need a big oil pan or a lot of rags) remove the pan filter... and remove that plastic hose and inspect the rubber O rings on both sides replace as need be. then put it all back the same way. make sure to read the tms also there's a bolt tighting guide for the pan in there. good luck.
