#2 injector is leaking on A2 Multi Fuel
hoop
14
va
Pull the injector and check out the copper washer on the bottom.
This is a super easy task.
Floridianson
2,521
Interlachen Fl.
Welcome to the Machine. When ever possible take pics or as much info as possible.
Is it leaking from around the orange dust cover?
Is it leaking from the plastic lines that connects the injectors.
If leaking from the injector bottom as in copper washer I might just try and backoff a little and just retighten before I took it out. If it does not work you did not lose much time.
hdexpert
Worthington Ohio
We recently swapped injectors in my deuce and found one of the brass crush washers was pitted a bit. When you cranked it over you could hear a loud air leak coming from that cylinder. Easy fix, remove injector, swap out washer, done. Hopefully yours is this easy to fix, good luck!!
pigfoot63
Gainesville, Ga.
While your checking look at the bolt length holding injector in. Sometimes you will find that the bolt has been replaced with a sightly longer bolt that has bottomed before it tighten.
jimmcld
Denton, Texas
I've had problems with injector lines breaking and #2 seems to be the most prone to this condition. It will break down inside the fitting that connects to the injector.
Hooty481
Russell County Kentucky
I pulled the injector out and and it looked alrite. so i put it back in and now it feels like there is compression on the orange dust cover. I pulled it back out and made sure there was nothing keeping it from seating good and reinstalled it it feels like there is less now but still a little bit. How tight do i need to tighten the 2 bolts that hold the injector in. Also i dont think it is leaking fuel anymore but now just the compression.
