250 cam thrust plate and timing cover busted
73m819
328
gainesville, ga.
What would cause the cam to push toward hard enough to bust the cover but the motor still runs ?
Hey any ideas on this?
Wrong thrust washer spacing, according to the TM, there is Two different cam thrust designs
From tm-9-2320-160-34-1, page 3-208
"Measure shim(s) (12) as a pack with micrometer. Add or subtract shim(s) (12) from pack to provide
a clearance of 0.001-0.005 in. (0.0254-0.127 mm) for engines with camshaft thrust plate or​
0.008-0.013 in. (0.2032-0.3302 mm) for engines with camshaft outboard bearing support".
