3 batteries?
illtemper
Whitehall,MT
well it's actually a 5ton ,not a deuce, but...
I have 2 interstate batts in my batt box right now ,no problems,but I have room for 1 more. I like the idea of having a spare onboard .is there any way to keep the 3rd batt charged? I'm thinking I can just switch cables once a month or neck down the 24v to 12v on a jumper to just that batt.
any ideas ?
thanks...Jon
swbradley1
Modertator
1,906
Dayton, OH
I thought the 5T has 4 batteries?
Anyway, you could wire up two in parallel and connect the other in series with them to give you 24 volts. I'm not sure I'd want to mess with it though.
Wire up a Solargizer or a solar charger on it (the third) for a less aggravating solution.
illtemper
Whitehall,MT
Re: RE: 3 batteries?
wow ,4 never crossed my mind ,I'll have to measure it but 4 might fit. I've never noticed (kinda new to all this). with 4 I can just wire up 2 sets of 2. thanks...Jon
1,141
RE: Re: RE: 3 batteries?
You would be far better served by having the third battery charged by the newer HMMWV alternator, which has a 12V output and a 24V output. That would give you a constantly charged 12V source for all sorts of nifty accessories.
:D
jwaller
19
Columbia, SC
5t is supposed to have 4 batteries but 2 will work fine if you live in the lower 48 and dont have any cranking problems
ida34
35
Dexter, MI
The 800 series had 4 batteries. I am pretty sure the older M39 series such as the M54 with the gas, mack or multifuel had two batteries.
1,141
Re: RE: Re: RE: 3 batteries?
jimbo* said:
Sorry to hijack the thread, but where would one acquire such an alternator?
I have occasionally seen them on eBarf, in beltfed34's store.
