395/85/20 do they rub
willy
Martinez, CA 94553
It looks like they are very close together on the tendem 395/85/20 tires
Is this a bit to close together what about rocks they do not get wetched in between and brake the swaybar or what it is called
Willy
5,123
Rocks and stuff can get wedged. But on the road if the dogbones are good, they won't rub on the rear. They will rub on the J pipe and inner fenders up front if you're using stock rims.
YOUNG GUN
10
Sherwood, Oregon
I have had zero issues of rubbing or rocks getting wedged on my A3, couldn't be any better IMHO.
I've even "flexed it out" (to the max) both front and rear with my Hyster and they don't rub anywhere.
Also done plenty of offroading with no issues.
Hope this helps, and good luck !
tie6044
51
Blaine, MN
I think it depends which rims you use also, if you go with stock deuce rims they will rub on the steering drag link at full right turns. I have mine on modified HEMTT rims and have not got them to rub anywhere. I think A3 rims work just as good also.
trider
Seminole, OK
I know this is an old thread but thought I would ask a question relating to this. Will the fronts rub on a M35A2 using MRAP wheels and adapters? I have 365/85R20 on steel wheels as well as 395/85R20 on aluminum MRAP wheels and trying to decide which to use on my bobber project.
