- 1,161
- 113
- Athens, Ga.
Ok, as many of you know, I just pulled the heads off my multifuel for a leaking freeze plug.
I need to know what the general opinion on retorquing the heads is........
My instruction sheet that came with the gaskets said to start at 110 ft. lbs, then 130, then 157, then 157 again. I let them sit app. 24 hours between the first 157 torquing and the second.
I have now run the engine, should I do them again? It idled for approximately 20 minutes, then I drove it a couple of miles over to a friend's house, then it sat idling for about 10, then I drove home, more idling.
If you do recommend retorquing, is that hot enough to go ahead, or do I need to drive it a little longer?
The 465 gasket has been updated so many times, I figured I would trust whatever instructions came with it. It is kind of ambiguous, here's what it says:
Applicable Standards / Specifications
A. DODO-STD0010
"It is not recommended to hot retorque this gasket. if any seepage or leaks occur, or if a torque check is required, it must be done on a cold engine."
Cylinder head gasket 12380040
Now, to me, that seems to say retorquing is only done if there is a leak. Am I misreading this?
I have built a bunch of gas engines (multiple small and big block Chevy's, Mopars and a couple of Hemi's as well) and I don't remember retorquing any of them after they had been run.
Opinions and experience, please.
Thanks fellas
Clinto
A. DODO-STD0010
Thanks fellas
Clinto
