4l80 internal harness
erasedhammer
61
Maryland
So turns out my internal harness for my 4l80 is flooded and needs to be replaced .
Hummerpartsguy has one but is charging 200 for it, practically highway robbery.
Amazon and other retailers have a similar looking harness that says it's for a 4l80e transmission and only for $50!!!
Can anyone confirm that the harnesses sold on Amazon and other sites fit the Humvee?
Wire Fox
161
Indianapolis, Indiana
I can't speak for quality, but those Rostra harnesses should fit just fine. They're made for ALL 4L80E transmissions beyond a certain early model year. If you have the coolant lines that are spacer farther apart, you can guarantee that it will work out fine.
Wire Fox
161
That amazon link shows the big connector and 6 smaller connectors?
I'm not 100% sure it's correct, but you're looking at the exact same harness on Amazon that I decided I'd be buying if my trans turned out to need one. So, I supposed you can say I'm confident enough that I'd have chosen to spend my money on it. Perhaps that's 99%?
erasedhammer
61
Maryland
Sounds good enough for me.
