Hi there.
My 1988 Humvee M1097A2 (rebuilt by Army on 2013) with a 4L80E transmission and a 6.5L NA has the trans light always on as soon as the ignition is turned on and goes out after the ignition is turned off only.
I followed the DVOM procedures to check the error code 73 and realized that the pressure solenoid was with the resistance out of range (6.7 ohms). I replace de solenoid and also the internal harness, as the trans conector was full of oil. The oil is at the correct level as well.
The truck runs great and all the gears shifts perfectly, even before the PCS and internal harness replacement.
Anyone had this issue? Any idea how to solve this?
Thanks!
Thanks!
