5 ton window removal problem
mike winterton
california
Just got an m923a2 and i'm trying to figure out how to remove the glass window. I've removed the access panel and disconnected the mechanism clips. The window will slide out only about 90% and then is stopped by something. What is the trick to get it out?
tie6044
51
Blaine, MN
There are two little brackets at the bottom of the window that prevent it from coming out of the door. They have two small screws in each one.
jcappeljr
27
Delta, PA.
Make sure the 2 little clips and the 2 stops are removed.Sometimes you have to give it a good hard pull upward.
Artisan
229
CDA Idaho
That's the easy part! Wait till you want to replace
the rearmost vertical channel and you find the screw
that holds it, that is inside the door at the bottom,
wait till you try to unscrew that bugger and find it is
all rusted up! That was FUN! I goter' but dang!
It was removed one microscopic piece at a time!
