6.2L civi vs Military Exhaust manifold
stevee
norwalk,ct
Hey all, over the summer I bought a beaut of a CUCV and recently the crank failed, and upon inspecition found a crack in the block. I've got a civi 6.2L from a 1983 van that I'm swapping in. I've seen alot of informative posts in this site regarding the differences in the engines and they've answered alot of questions that I would have had, but one remains unanswered. On the drivers side exhaust mani on the civi engine there is what appears to be an exhaust brake. 1/2 the vac lines have been cut, and the electrical connector (2-pin weatherpack) is gone. Is there an easy way to hook this up? Should I swap exhaust mani's and call it a day? Any help and experience is greately appreciated. Thanks much guys.
67_C-30
Sweet Home Alabama!
I would stick with you manifolds. If not, you risk having problems connecting to your existing exhaust after its in the truck
Welcome to the site!
67_C-30
Sweet Home Alabama!
BTW, that is the EPR (Exhaust Pressure Regulator) and it controls a valve in the manifold. It restricts the exhaust on that side to divert it up to the EGR in the intake. This only came on C code engines. Make sure you put your non EGR J code intake off the military engine as well.
stevee
norwalk,ct
Thanks for the welcome and thanks for the help as well!
We're in the process of swapping all the senders now and noticed the EGR valve on the intake after we took the filter off. We decided to swap that as well... then noticed that the civi engine seems to use a form of TPS on the injection pump as opposed to the vac operated solenoid for the trans. So it looks like we'll be swapping the injection pump too. As well as all the glow plugs, sensors, brackets etc etc which is pretty strait forward.
Thanks again for the help, anything else you can think of that might through us for a loop?
sandpirates
Akron, OHIO
you might want to look for some M998 exhaust manifolds they flow better. at least that is the info my shop chief tells me. if any one has better info let me know.
67_C-30
Sweet Home Alabama!
The H1 headers do flow a little better, but they require the exhaust being altered to fit. Some people have mentioned they don't work well on the trucks because of clearance on one of the outlets, but I've personally never tried them. I usually turbocharge my engines, so I have no need for them.
67_C-30
Sweet Home Alabama!
No, that's pretty much it. The civi engines and CUCV longblocks are interchangeable once everything is stripped off them. Good luck with the project and give us a yell if you run into a snag.
Tanner
11
Raleigh, NC
And some folks will say 'use an exhaust manifold gasket between head and header', while others will say 'leave them off' -
'Tanner'
