6.5 to 6.2 parts interchangeability?
broylz
Gallatin, TN
Im looking at buying a 1996 chevy truck that has a 6.5 TD and a 700r4 4x4 drivetrain. I am aware that the truck turbo manifold system won't fit the humvee amd i will be looking for a van intake and manifild system.
My question is on the 12v conversion. What parts could i put on my 6.2 block to maintain its strength over the 6.5 block issues? Glow plugs? Gp controller? Starter? Alternator?
And mechanically, is the serpentine setup a fit? Will the heads bolt on? Are the injectors different?
For the few hundred bucks this truck is for sale for, it seems like a cheap way to add most of a turbo kit, upgrade heads, 12v conversion, and overdrive conversion...
broylz
Gallatin, TN
Also, plan is to add a marine pump to keep up with the turbo and maintain the mechanical injection. Same reason for using the 7004r, no electronics
ken
26
Houston Texas
If the truck is stock it will have a 4L80 transmission behind the 6.5. Not a 700R4. NDT is correct the turbo heads for the hummer/van models have a different angle for the intake bolts. Along with a turbo mounting port on the block for the oil feed and return on the turbo. All other parts are interchangeable
Retiredwarhorses
4,464
Brentwood, Calif
Don’t waste your time and money, if your looking to upgrade your HMMWV’s drivetrain, just buy a takeout Military turbo drive train.
