7/8 wrench with 1/2 drive for M35 A2 head bolts
gel69
Bartow Florida
hello,
I am currently doing a head gasket on my 1983 M35 A2 multi fuel White motor , an I was hoping I could borrow a 7/8 wrench fitted with a 1/2 drive on the other hand in order to torque the three bolts located below the injectors.
If someone has on handy I would appreciate if they would let me borrow it thanks
I will pay for shipping if needed.
thanks
Gil
Bartow Florida
CARNAC
The Envelope Please.
681
Corpus Christi, TX
There is one on epay I think this is acceptable. I would suggest going this route since the ship in and out with tracking and what not would be almost as expensive. Look for Proto 3/4 torque and it should bring it up. He has multiple ones.
acesneights1
23
20
CT
if your a good welder. The ones most of the vendors sell are thin and will break anyway. Search it on here.
CARNAC
681
Corpus Christi, TX
Oh that thar is upper level math. That makes my head hurt.
I do purdy well at the middle and lower level math. You know, countin on fingers and tows.
Speddmon
Blind squirrel rehabiltator
30
Cambridge, Ohio
just an fyi.That will require a recalculation of the torque.
http://www.cncexpo.com/TorqueAdapter.aspx
You are correct, luckily that is why the manufacturer knew that already and supplied the measurement for the torque calculation...Proto Tools...2"
Mine is only a 3/8" drive, so you'll need to use a 3/8" to 1/2" adapter for it to fit the square drive on your torque wrench, but those kind of adapters and extensions don't necessitate a torque recalculation since they are still inline with the centerline of the square drive of the wrench.
I thought if you put the adapter 90° to the torque wrench you didn't need to adjust the torque setting. I could be wrong though. It's been a while since I needed to adjust torque because of an adapter.
That's correct .
Yes, that is true as well. But it is also a pain in the butt sometimes to gain access to the nut you are working on with the wrench and adapter at 90 degrees to each other. Why not just plug the numbers into the easy calculator provided in the link by acesneights1 and readjust your torque setting.
JasonS
199
Eastern SD
I purchased a snap on adapter and it doesn't fit in all of the locations. I ended up building one from double box end wrench and a socket. In building one, I can say that the weak link isn't the weld but the mild steel link between the wrench and the socket.
m-35tom
226
eldersburg maryland
unless the drive is directly above the nut or bolt you have to calculate the torque adjustment amount. not rocket science, and it's your head gasket.
Speddmon
30
Cambridge, Ohio
Thanks Phil, I've been busy here around the house so I haven't sent it out yet. I was planning on getting it in the mail tomorrow or Wednesday at the latest.
m-35tom
226
eldersburg maryland
do not use mild steel
