802A question
Slate
378
Ozona Texas
The little glass fuse in holder behind main guage panel. Mine was burned out when aquired. Is this for battery charging and should it be a 6A 32V 311 glass fuse or should the A be higher? I also have the 24volt pulse charger from military on mine. Can it stay hooked up when gen is running or does it need to be saved for storage of the unit to keep Batts up? Thanks
Sent from my moto z3 using Tapatalk
Slate
378
Ozona Texas
My notes say: Battery Charger Fuse (FU1): F03A125V30A BUS ABC-30-R
Thank you sir I wonder why they had a 6A 32v fuse in there? I can see why it was blown. I will put the correct one in. Thanks again.
Guyfang
26,019
Burgkunstadt, Germany
Both of you are right. And its a 30 amp fuse. 125Volt. I stand corrected. But the one Zed listed is the right one. Easy to find. Buy several. You dont know why its bad. Or is it missing?
rcamacho
914
Bainbridge Island Wa
FU1 was blown in mind as well. I purchased a few from an auction site...
After replacement the battery charging circuit works to spec
Guyfang
26,019
FU1 is one of the items that is often stolen, along with the cap. And if its not stolen, it can be found in a corner of the control cube, hidden behind something. Its not unheard of, to find 2-3 of them, caps and all there.
Zed254
467
S. Hampton Roads, VA
The one on my 802 was stolen.....along with the cap. I never could understand why someone would grab the fuse and part of the holder......
Slate
378
Ozona Texas
Couldn't get picks to load on pm but here is 100% load and now I've got smoke. Normal or?IMG_20190927_192045331_HDR.jpgIMG_20190927_192034596_HDR.jpg
Slate
378
Ozona Texas
Kinda has an odd loaping sound above 50% here is guage reading everything looks normal.IMG_20190927_192342076_HDR.jpg
Slate
378
Ozona Texas
Howdy,
Sights and sounds.
Some MEP-803 and MEP-802 being run off a load bank.
Acquired a Military surplus load bank
I like that thanks. I loaded it to 100% and ran it for a few hours. It smoked pretty good untill there was some sort of noise and it cleared up quickly. I dropped it back to 75% and then back up to 100 and it was smoking again just not as bad. I think I need to run the crud out of it for a while. Maybe it was run with a small load on it and wet stacked.
Guyfang
26,019
In post #14 you hertz meter is low. Always set the hertz at 60, and leave it there when you shut the set off. Volts and hertz should not need much adjustment. Yes, when you start at no load, and ramp it up to higher loads, the hertz may drop a tad. That's normal. Just turn it up a bit to compensate.
Slate
378
Ozona Texas
Thanks I didn't mention Hertz meter is just loose inside it's case it no work. Was useing kilowatt meter from Lowe's inline. Was running 60-61 Hertz. Stayed consistent. Need to find a good take off meter.
Slate
378
Ozona Texas
How about the fuel lines going to the injectors, when the lines leak or crack, which they will,. Do you replace the whole thing as a unit or can you replace the hose? And where can you find that hose? Looks like it is clamped into fuel rail to me.
Guyfang
26,019
Take the meter apart. Every once in a while, they are fixable. sometimes the meter comes loose in the case, and the two tiny wires get broken, Its really not hard to fix. Worst thing that can happen is it not work when you are done.
