809 series owners, radiator question
5,160
Would anyone be able to help me out a bit? I've searched a bit, but I haven't been able to find the info I'm looking for. I need the actual dimensions of the 800 series radiator. I've ran into a bit of a snag on my M931/MK48 project when it comes to the radiator. I think perhaps a 800 series will work in place of it though. Also if someone could post pics of the radiator inlet and outlets. I've been studying the TM's and I see it's ports line up like I need to. I just have some question about the lower port. It appears to have a 45* angle on it?
1,193
Does this help?
5,160
That's the same pic I was looking at in the TM, wanted to see a real life pic mainly of that lower port. And most importantly, measurements.
1,193
2.5 feet of snow in the last 2 days. The TM is the best I have to offer right now.
Those pics Joe posted in GA, with green grass almost made me sick.
5,160
Ok I did a little google image search-foo and confirmed the 45* bend. I still believe this will be workable.
Just need the measurements. I guess tomorrow I can go to CSI and see if they might do a little bartering with my 931 radiator for a 809 series.
gimpyrobb
dumpsterlandingfromorbit!
27,787
779
Cincy Ohio
So are you having cooling troubles now that you've added a second fuel line to your truck? I thought it added a little power, not a LOT! I wonder if my deuce would benefit from a second fuel line. Drew, your the man!
5,160
No I'm not having "cooling" problems. The problem I'm having is that the 931 radiator will not work flipped 90* for my M931/MK48 project. Like I noted in my first post.
