816 rear clutch lever leak
catskillpond
wurtsboro ny
Finished replacing all the brake lines many almost rotted through at the axle hold down clamps, Finished off bleeding the brakes and noticed small air leak for air supply for rear clutch handle replaced hose at frame main air supply then clutch handle started leaking slightly worked it awhile still leaks. Are these rebuildable thought might replace with a ball valve and a longer handle. Thanks
