920 tire
73m819
328
gainesville, ga.
Can someone tell me for the 1100x24,
1--the speed rating
2--load code (H, J)
3--the inflated height
4--will the 24" rim match the 5t lug pattern
Castle Bravo
Hundredaire Socialite
231
Arizona
Goodyear G286 11R24 -
1 - Speed Rating - 68 mph
2 - Load Code - H (8270 lbs single, 7610 lbs dual)
3 - Inflated Height - 46"
4 - 24" Rim is 10 bolt, will fit on a 5 ton. See photo.
Ferroequinologist
Resident railroad expert
4,812
748
Liberty Hill, SC
I'm thinking my next upgrade to the M915 will be 24in rims and tires, for just a little bit lower RPM at the speeds I run now, plus the ability to 'push it' a little if I'm running behind.
73m819
328
gainesville, ga.
I had the idea to put these on the front of the 819, the 46" shoots that, the 1200x20s on the rear is 44", all well
Speddmon
Blind squirrel rehabiltator
32
Cambridge, Ohio
Ron, I would suggest changing them all over to the 24's but YOU don't need any more road speed. You're the only person I've known or heard of taking a 36000# truck airborne
73m819
328
gainesville, ga.
I would like to put on a nice HEAVY rated steer tire, no point changing all the tires when I still have 13 1200x20s, thought I might in the future be able to pick up a pair of the 1100x24s fairly cheap as thay are a military tire
