925 A2 winch doesnt work
Scar59
42
Mt. Eden, KY
Start under the truck, at the selector valve. Are you certain the PTO is engaged? Hydraulic pump turning? Be very careful under the truck. Disconnect the selector cable from the valve, lube, clean, adjust if needed.
Work selector valve manually. Have somebody with you for security.
Tinstar
2,567
East of Edmond, Oklahoma
This was the problem on mine.
Winch worked great at first, then nothing.
Found the thread that said to check this.
Sure enough. That was the issue.
Cleaned it up and a little lube and it works like a champ again.
