94' MEP-803a Starting Issue
Bmxenbrett
30
O man that dosnt sound good. Your getting the engine starter to turn the generator side but not the front engine pully? Could be a missing/broken key in the pully, broken crank or just a stuck belt making it look like the pully isnt moving.
Guyfang
26,211
Burgkunstadt, Germany
The first thing that comes to mind is this. The bolts that connect the engine and the Main Generator coupler plate are Missing, broken off.
Pull the injectors out, and turn the engine over with your ratchet, see if the engine will make a couple of revolutions.
Be advised, if water has leaked into a cylinder, that could be your hard stop. With the injector removed, this fluid WILL be ejected at considerable pressure. If you are standing someplace in the "line of fire", it will be unpleasant.
