Aftermarket Trans and Oil cooler
caladin
So Cal
I was at my local junkyard when I saw these two coolers attached to a pickup. So I picked them to do some modding. Anyone setup a aftermarket trans cooler and Oil cooler infront of the Radiator? An tips, pics, ideas?
kapnklug
spencer,ny
I installed an aftermarket tranny cooler, trans temp gauge and trans pressure idiot light (lets me know if I just ripped out a trans cooler line on a tree stump). Cant get any pics since its all buried behind the front grill now. I mounted the cooler with L brackets to the sheetmetal in front of the radiator, and plumbed it inline and after the stock trans cooler.
Originally I planned an aftermarket oil cooler also, but the plumbing started getting really complicated and it seemed like I was just creating alot of potential for a catastrophic failure. Also keep in mind that the stock oil cooler in the radiator is also an oil WARMER in the winter; you don't want to bypass it.
Grega
St. Paul Nebraska.
Make sure you install inlet of your aux. cooler after the cooler in the radiator outlet side, which is the top line on the radiator by the coolant tank.
