Air brake issue
remanzi
woodbury, ct
Have a 1987 AM General M939A1 5 ton. Air brake pressure should top out at 120 psi. Pressure now runs up to 150psi before the safety valve releases. Thought it was the air governor and replaced it. Did not fix problem. Compressor is working but air is not getting to the governor. Anyone have a similar problem and any suggestions?
simp5782
Feo, Fuerte y Formal
9,509
Mason, TN
Pressure protection valve
Does your horn and wipers work? If no, replace the PPV
If yes, remove the flex line from the governor a d remove the small line at the dryer and blow thru it. Sometimes the cotton jacket line can come apart internally and clog the dryer purge signal line up
remanzi
woodbury, ct
Thank you for the quick reply. I will try blowing out the lines and look to replace the PPV if that does not work.
