- 820
- 220
- 43
Hey Guys,
Over the past month or so, I've tried to go through the forums here to read up on as much stuff as I can. I've also been using the TM's and have all of them downloaded.
As per this problem, I haven't found anything in the TM's or the forum, related to this specific problem, if there's something in the TM's posting a pg # would be a great help. If there's a thread here on SS that may help, a link would be great also.
We have a 1986 M1008, it has low miles (12600) but was an electrical mess. Well, not as bad as some I have read about on here, but still needed a lot of going through. Electrical work isn't my strong suit to say the least, especially if it comes to using wiring diagrams. But most of the electrical work I have done is just simple end connector changes, repair broken wires, and other odds and ends.
The truck already had the 12v resistor bypass done before we got it, and the resister is MIA.
Here's what we've done so far:
We've replaced nearly all the electrical connectors by soldering on new terminals ends and using heat shrink in the following areas: From the battery cable ends and Terminals, All wires that connected to the 12v block on the firewall (replaced two pole block with heavier mil spec single pole block),
and all Terminals- pigtails- main power connectors = etc on both Alternators. As all of these connectors were either poorly done crimp connections, or just in poor condition due to age.
I have also replaced all GP terminals with the newer style wider terminals, along with a full set of new AC 60G GP's.
Also replaced the GP Controller Card with CUCV Electric Upgraded GP Card, and added in an emergency Manual GP Momentary Safety Toggle Switch.
Replaced the Under the dash relays (which go to the voltmeter and 2nd Gen Exciter relay?). Something interesting here was that instead of two relays, there was only one relay and one empty socket. So I took the one old relay out, and put in two new relays from CUCV Electric, filing both sockets.
Doghead Starter Relay Mod Upgrade.
That's all the electrical stuff that we've done that I can think of, might have to add something if I think of it later.
Ok, so that's some background on the truck up to date.
Now, here is the problem I've run into:
When I fired up the truck this evening after finishing the last of above electrical work, it ran fine. Dash lights came on and then went off as normal. No alternator lights showing after start-up, voltmeter is in the green. Everything looks good.
But after the truck was running maybe 5 minuets, we were looking at the Drivers side Alt belt, and thought it needed tightened up a bit. So I shut the truck off and proceeded to loosen the Alt adjustment, but as I was doing so, I put my hand on the Alternator casing, and it was surprisingly hot! Very hot, almost to the point it could burn. I felt of the passenger side alt, and it was almost cold to the touch.
I've looked at all the connectors on the Alt, everything is where it was before. I didn't change any of the wires around. I just replaced the end connectors and placed them back where they were.
So, after trying to look things through, we decided to get another Alternator, thinking it could have been an internal problem in the Alt itself.
As a side note here, I drove this truck back from Arizona just a few months ago, which was about 1700 miles. During that trip back, I did notice that the voltmeter would sometimes wonder into the yellow, but would usually return to green territory shortly. But I never thought to pop the hood and see if it was hot to the touch. So I don't know if it was doing that then or not. Never heard of an Alt getting hot like this before.
So after doing some more research here in the forums, I went down town to O'reilys and picked up a 01-0136 Alternator. (I think it supposed to be for a 75' Caddy Commercial?)
Installed the new Alt, fired up the truck, and had the same problem. It started to warm up pretty good only after 1-2 minuets of running, and the passenger side still fairly cold. Shut the truck back off before it got hotter.
So, I went and pulled the under the dash relay that was missing before. I believe that this relay goes to the alt 2 exciter?? At least that's what I read here somewhere.
Anyway, Started it up again, but problem persists.
Does anyone have any idea what the problem could be? Surely this isn't normal?
There are two wires which I have been unable to identify, nor can I find where they used to go. One is an orange wire which is going into the wiring harness just below the GP Relay. And the other is a black and white stripped wire going into the fuse box underneath the dash. Both wires have just been cut and were just sitting.
Could either one of these wire be the problem? Could they have anything to do with the back-up lights (as they are not working)
Any other guesses on what they are for?
I'm posting a couple pics below of the drivers side alternator and the two mystery wires.
Any help would be Most Appreciated!
Thanks in Advance!
Thanks in Advance!
