alternator pulley in wrong place
diverman555
9
Detroit, michigan
I have gotton 2 different alt pulleys from guys and both were wrong. the first I found was from a 465 multifuel. but the next should have been right, but no #'s on it. It went on good, but when I put the alt on the pulley was 3/4" behind the main pulley's it would have thrown then off. So I rook it back off and moved the bracket to the front, put it back on and still 1/2" off. Is the pulley nut resessed inside the pulley
because this one is just flat. does anyone have a correct part # for one. I called 2 parts houses we have listed one said he had a new one for $95. the next place called me back and said they had a used one for $140.00
Does anyone have any answers or suggestions?
diverman555
9
Detroit, michigan
I pulled the alt part number from the TM and it shows to be correct, the pulley did not have a number on it.
My alt looks nothing like the one in the picture, mine is twice the size.
It is 9.5" long, 8.25 from outside to outside bracket legs and another 2" that the shaft sticks out of the front. PN# 10929868
319
Lieutenant
3,347
58
Michigan
It would help others to know what you're working on. I assume it's your M923, but others my not.
diverman555
9
Detroit, michigan
I found the correct alt pulley on ebay for $29. It is recessed on one side and has about a 3/4"
area where the shaft goes on the other side. I matched the #'s also so it will be here Wed.
diverman555
9
Detroit, michigan
alternator
sandcobra164
323
Leesburg, GA
I hate that the one I sent you was not correct. I pulled it from a M923A1 just as your truck is, still had the belts on it when I got to it. Perhaps they have different alternators, the pulley came off a 60 amp for what it's worth and every M939 I've come across has that same alternator.
sandcobra164
323
Leesburg, GA
I figured it out today while working on the M818. The 800 series have a recessed pulley on their alternators like the one that you described as lining up with your set up . You purchased and 800 series alternator and that's why the 900 series pulley that I sent you didn't line up. Both of them are 60 Amp alternators but different brackets and input shafts and the cases are slightly different as well. I'll see if I can dig up a 900 series alternator next week, use the pulley and brackets that come with it and you should be fine!!!
