Jeepsinker
- 470
- 83
- Dry Creek, Louisiana
I was considering installing an aluminum tank that I have here from a five ton by just cutting a hole for the deuce pump and drilling and tapping screw holes, but the filler neck on the tank I have is in the wrong spot. I noticed an aluminum tank on the M35a3 that showed up at the Ponchatoula rally, but I never figured out who owned the truck. I was just curious as to whether it was factory on the A3 or not. I'm pretty sure I could make a passenger side 5 ton tank work, but the tank I have is a driver side. I'm just trying to do away with the tank rust issue for good.
