Another M1102 lighting question
Mr45
Sarasota, FL
I have an M1102, 2007 mfg, with normal incandescent tail bulbs. Changed those out, and wired in a 4 pin connector per the many threads here.
When I powered things up, all the lights worked properly, with the exception of some of the (they appear) LED Markers.
3 run much dimmer than the others.
Does anybody know if all those marker LEDs are the same? Some run on 12-24 and some on 24 only?
are replacement bulbs or LEDs in 12vdc available for them?
thanks!
eta. Played with them some more, ground seems good. I think the bulbs are shot. They come up bright and then dim down. Amazon has them for $1.75 each. I think I'll just get a handful and replace the weak ones.
emmado22
164
Mid Hudson Valley NY
Some contracts for the 1101/2 trailers specified 24V Incandescents, some specified the 12/24 LEDs. It all depends on when your trailer was built.
