Brad
- 105
- 43
- Bolivar, Pa
You guys are probably tired of me asking on here? I know I am very tired.
So this truck has ran fine since I discovered that clogged gas line. And everything should be all tuned up because we replaced EVERYTHING except the ceramic dist cap which looks fine.
Spent the last couple days going over the exhaust system trying to quiet it up some. Really only welded shut a couple small holes in the pipe and muffler, and putting in new donuts.
After that was all done, would not start! Even when we had fuel line trouble it would always start. Now no start.
Checked and had plenty of gas to carb, but the spark at #1 plug looked mighty weak. Talked to a couple friends and the concensus was that the condenser may be bad, even though it was a new one. Started to change it and discovered the screw that holds it in was nearly out. So tightened it up hoping that was the trouble. NO, still no start.
So we changed back to the original condenser we replaced when we initially thought it was the trouble?
It started right up, but did not seem to run well. Took a road test and it ran, but very little power, bad.
So we checked our point gap, was good at .022 as the manual says.
I had my son turn the engine over while I watched for spark at the points. None there, but a big strong spark jumping from the negative pole on the coil up to the main contact of the coil that is where the dist cap goes in when the cap is on, that is distributed to the plugs?
Is this something wrong, or will this stop when the cap is in place, and then spark will be sent the points?
I am sorry to bother you all with my troubles, but we have no where else to turn to??
Thanks in advance for any help.
