Antanni bracket bolt size?
REDWOLF
Risingsun Maryland
Any one know what size bolt is needed to mount the antanni brackets to the side of the M1009 trucks, short of trying a bunch at the hardware store. What tread course or fine. They look to be course.
ssdvc
640
CT
Yes, they are 5/16-18 course thread.
HOWEVER !!!..................do not try and use galvanized bolts ! The coating makes them very hard, if not impossible, to thread in, even after you chase them with a tap. If the bolt binds up, it may cause the nutsert to loosen and then, like me, you will have to weld the nutsert to the body to get the bolt off.
I went ahead and welded all 8 of mine after that, but it was a hard lesson to learn.
