Any idea of where to find the 2 hard lines coming out of the transfer case?
kfrosty
Belmont, NC
As I posted in some other threads I had a drive shaft break. I finally got in on the lift today and it wrapped around 2 of the hard lines coming out of the transfer case and look like they go over the top of the transmission.
I'm going to dig around on ebay and probably post in the parts wanted but also wanted to check here and see if anybody knew of a place to get them. (I'll check with kascar next week.)
Action
1,561
East Tennessee
If they are between the T/C and the rubber hose, they are from inside the T/C and part of the cooling loop. You will have to take the case apart to replace that.
kfrosty
Belmont, NC
No the are on the other end of the rubber hoses that are on the stubs coming out of the transfer case. Think they connect they go into some other rubber hoses on the other side of the transmission and connect to cooling lines as you suggest going to the front.
Action
1,561
East Tennessee
they are preformed tubes that are fairly cheap to buy OEM. The are in the parts TM in the end of the transmission section. they are cooling lines.
if you have old driveline, you need 12338333 and 5583650.
a2 versions use 12338333 and 6002779.
the different lines go directly to the trans port. different transmissions have the cooling stibs in different spots.
you could temporarily use 2 long pieces of hose until you get the replacements.
kfrosty
Belmont, NC
Based on numbers from Action, I found this 12338334
That looks like the line that comes from the Transfer case and threads into the transmission.
Of course
12447075 looks somewhat similar as well.
