peashooter
- 209
- 63
- Hanover, minnesota
Well I've been trying to fix this air assist since i got the truck a year ago. Its started leaking pretty bad from one vent on the bottom of the draglink. Anyway I started off with replacing the piston cup inside the ram, removed the frame rail mounted regulator as most folks suggest and replaced all the hoses. put it back together and turned the wheel a tad and heard a noise.... looked under there and found the link slipped back then realized the link casting broke. Looking at the casting break its got a different color metal where the break occured and a fair amount of porosity so i'm guessing the cast part wasnt great to begin with.
I still have the leak too... it appears the drag link only works in the one direction. Any ideas on where to find a used drag link and Bracket? I can probably machine a new bracket out of a big block of aluminum if I need to but i've got no ideas on the Drag link. (I cant afford a new one)
