Anyone have an exploded diagram of the front axle?
acetomatoco
9
Your TM 9-2320-244-24 of 12/67 has a most wonderful Illustration of the "exploded" solid front axle in the M715 series
Davidwyby
244
CA
Re: RE: Anyone have an exploded diagram of the front axle?
jimk said:
http://www.pirate4x4.com/tech/billavista/60_front/
I don't see an M715 closed knuckle 60 anywhere.
Davidwyby
244
CA
Eh...a repair manual?
Davidwyby
244
CA
You are not logged in or you do not have permission to access this page. This could be due to one of several reasons:
You are not logged in. Fill in the form at the bottom of this page and try again.
You may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
Looks like I need to register over there...
tacoma
Tooele, UT
David,
I've got the right manual as a PDF, PM me your email and I'll send it to you. The closed knuckle is sufficiently funky that a manual is helpful, if you've never done it before. :D
Wolf.Dose
10
Boehl-Iggelheim, Germany
In the 34p manaual there is an exploded view. In the 34 manual are some tips to set the axle togehter again. It requires some special tool. These you can built yourself with some minimum skil. Try it, I did it too serveral years ago. The axle still serves me.
Wolf
