armasafe plus battery maintenance
319cssb
221
Easley SC
Has anyone done any maintenance on their armasafe plus battery? I know they call it a 'sealed' battery. But it seems to be a wet lead acid battery regardless.
so there may be a way to check and level up the battery with distilled water.
dmetalmiki
2,036
London England
If it is a sealed battery,(Of any type), Then no, there is no maintenance required.
That is the whole point of the battery being of the low maintenance type.
They are specially vented. (for pressure evaporation).
A good low trickle charge 'intelligent' battery maintainer is is a good idea to leave attached.
They are usually (Should be) Lead acid, Gel, and A.G.M. Suitable.
319cssb
221
Easley SC
Most sealed batteries are sealed not with the consumer in mind. With time fluid evaporates and the low level is what kills the battery.
The vent holes have plugs that can be removed, I was just wondering if someone has done that and filled back up.
NDT
7,441
Camp Wood/LC, TX
It's an AGM absorbed glass mat battery. All they need is an AGM maintainer connected 24-7-365 and they will last 10+ years.
155mm
Chief and Indian
503
Guymon, OK
I use this charger, Noco G7200, only reason I use the 7amp version is 24v capabilities.... have had this charger bring back 4 hawkers that I thought were goners.
dmetalmiki
2,036
London England
I've had gel batteries for 9 years in the 5ton camper, Still going strong,
And kept in condition by two individual 12 Maypole intelligent chargers.
Most all the British military batteries are of a gel type now.
6.T.N.s are still being surplus'sed though.
Guyfang
27,163
Burgkunstadt, Germany
These are probably the best, most robust battery's I have ever seen or worked with. Properly take care of, they will last at least ten years.
The he amount of "liquid" in the battery, and yes, it's more a gel the liquid, is mesured in tea spoons.
Guyfang
27,163
Thats something I have never observed. I had a battery charging shop in K-Town, that handled 30-35 batteries at a time, and we ran a 24/7 operation. Never saw a Armasafe leak, that had not been cracked in an accident/wreck.
319cssb
221
Easley SC
I have heard that they 'could have gotten wet overnight ' I wonder over how many decades of night, he is talking about now.
Guyfang
27,163
Have you called the Armasafe folks and asked them about this "water" problem? When I was contracting, I several times called to ask questions, and always got a straight answer.
