battery cutoff - is 300 amp enough?
Mike82ndABN
10
Tampa/Florida
good question, it just said 300 amp on the package, i would think that is probably at 12v though.
back of package says it is ideal for farm, marine, and motorsport 12/24v
Happyland1410
Ada, Oklahoma
I used a lockable switch from Flaming River that is rated for 250 amps continuous and 2500 amps for 5 seconds. It was not cheap but I am confident it can handle anything my Deuce throws at it.
http://www.flamingriver.com/index.php/products/c0015/s0005/FR1005
Here is a post showing how I installed mine:
http://www.steelsoldiers.com/showthread.php?2061-Battery-cutoff-switch&p=940649&viewfull=1#post940649
Here is another thread with a lot of good information:
http://www.steelsoldiers.com/showthread.php?113084-Battery-Disconnect-Type
Keith_J
1,328
Schertz TX
Had one fail at less than 100 amp and 28 volt. Voltage doesn't matter if you don't make or break under full load. Current is Current when made. THere are better switches.
Keith_J
1,328
Schertz TX
Higher voltage will arc contacts if you try to break it under load. I am also using a relay rated for 400 amps at 12 volts AND breaking under the same load which failed the switch. No issues yet. This is for the 28 volt, 80 amp cabin air conditioning system in my 1028. The relay controls the compressor motor. It cycles a bunch.
Keith_J
1,328
Schertz TX
If this is the same KeithJ from another popular board, then I know you know your stuff
x87
You found me ;)
Yes, in my system using both disconnect switch and relay, the disconnect is the same as pictured (low quality) and the relay a very high quality Trombetta of domestic origin.
