Battery Removal V-100
Philh
Lexington KY
Is there a trick to removing the lower battery out of a V-100? The brake booster is in the way, do you have to remove the booster?
Phil H
M813rc
3,653
Near Austin, Texas
Presuming you refer to 6TLs, since civvie batteries tend to be smaller - nope, just tilt the left side up and pull it out.
By 'just' I do mean wiggle it, squirm it, cuss and sweat a lot. Best not to have ladies or children nearby. This is from recent personal experience. :roll:
Cheers
B3.3T
109
SW Ohio
Rory is correct, it is not much of a problem. And I've not known it to be a problem unless your setup is not stock. I've seen other brake boosters used and mounted differently.
M813rc
3,653
Near Austin, Texas
I hadn't really thought of the booster not being in the stock place. Phil, does your setup look similar to this?
Cheers
ps- Wow! the site really squeezed that picture down and took all the quality... But it still shows what it needs to.
Philh
Lexington KY
I purchesed Jack Tomlin's V-100 years ago, put it back stock and sold it. I put new batterys in and the guy I sold it to called and ask me how to get the lower battery out. I could not remember having any trouble putting them in. I will pass on your info. Thanks Phil H
