IEHMMWV
- 0
- 0
- Coronado, CA
I have been experiencing problems with my battery system upon starting. When I start the truck, the positive terminal lug will shoot a nasty spark up out of the terminal in between the terminal connector. It has happened four times and in between multiple starts. This would be the terminal that connects the two batteries together. This ruined one battery and now i installed new Optimas and the same thing just happened. I have went through and removed every cable connection in the box, on the starter and on the block to clean and tighten thinking i have a loose ground somewhere, but now I am just stumped. There will be little molten lead splatters after it happens. The generator chargers great. The batteries are maintaining 25.4 volts. I even replaced the cable that connects the two batteries, but obviously that was not it. Has anyone else experienced this?
