big winch
JDToumanian
17
Phelan, CA
If my duece gets in a situation were it won't make it up the mountain i want to know i have plenty of winching power to drag it up and over the obsticle and not worry about sheering the pin i keep reading about thanks.
I'm certainly not trying to talk you out of putting a huge winch on your truck, but the 10k winch, properly rigged, will pull a fully loaded deuce up any terrain without any problem or shearing the pin. Remember that you can (should) use snatch blocks to double / quadruple the capacity of the stock deuce winch. This is why snatch blocks are a BII for winch trucks. I haven't read it yet myself, but I believe there is a TM on vehicle recovery available for download here on SS.
Regards,
Jon
sermis
17
Temple, TX
rizzo said:
a hydro motor bolts right to it.
depending on where your putting it it might be very akward to mount.
also that winch only has a 1/2 inch cable. Which is not an upgrade from a stock deuce winch.
Will that hydro motor work on a regular 5 ton winch? What would be needed to attach the hydro motor to the winch? I am wanting to add a winch to the rear of my M35 and this would make it a lot easier than running another PTO drive line to the rear and chains.
cranetruck
94
Meadows of Dan, Virginia
Massm35a2 said:
I have the winch from a 5 Ton on the front of my Deuce. It was on there when I bought it. I love the look. I still have to get around to hooking up the hydraulics.
I'm into different applications of the Black Out Driving Light at the moment and I'm wondering about yours, does it illuminate the winch/bumper or the ground ? Looks marginal.
I just received a BO light from Armyman30yearsplus (David) and will be doing some experimenting with the xm757.
Thanks,
spicergear
29
Millerstown, PA
I have one of the PTO style 20,000 5 ton truck Garwoods on the nose of my duece. These winches are VERY large and make the deuce 10K winch look on the small side. Because of my V8 CAT engine swap that is a shorter in length than the multifuel engines I was able to move the winch into the truck by another 4-5 inches. I extended the frame only around 7" total. It tucked in very nicely that way as I moved the radiator back by about it's full thickness.
Massm35a2
New Bedford, MA
Thanks,
It Illuminates the ground but, I do see some of the light reflect on the inside of the bumper.
