- 2,799
- 74
- 48
- Mesquite, NV
I replaced EVERYTHING on my M105's brake system except for one rubber hose and the PB cables (thanks Mark!). I blew brake cleaner through all the lines so I know they are clean and clear. All of the parts from the donor trailer look new, like it came off a fresh rebuild. The system still had fresh looking DOT5 in it.
After I installed everything I tried to vaccuum bleed it, but I'm not getting anywhere. It will hold a vaccuum on the system, but won't suck fluid from the master cylinder. The TM says to bleed it manually - is that the best way, when there is no fluid at all in the lines? Should I just hook it to the truck and pump the brakes? Do I need to build a pressure bleeder?
Any help would be appreciated.
