BMY wrecker power divider
tobyS
840
IN
Can someone please explain how the power divider on the BMY M939 wrecker works, possibly some pictures? Would it mount on a (91BMY) M931, given the short frame? It seems rather inefficient going through the Allison automatic. How about coming off the front of the engine for hydraulics?
Suprman
703
Stratford/Connecticut
There is a cab lever that engages the driveshaft that runs the wrecker body hydraulic pump. I believe its a special transfer case.
tobyS
840
IN
It is simply a PTO that mounts onto the transfer case. M936 wreckers don't have a power devider like the older wreckers.
Would an old style power divider work if I came up with one??...it had two take off's, right? Or was that just basically another transfer case, in line with the output of the first?
I wonder how hard one (pto type, not separate gearbox) is to find? I'm willing to come up above the frame rails. I have a double piston pump to drive.
Does the torque converter lock or can I make it lock?
73m819
327
gainesville, ga.
Two out puts, plus can be disengaged at the power divider, the pto at the transfer is live 100% of the time, the power divider has the sliding clutch to disengage the transfer driven shaft, also the drive for the rear winch can be reversed, IN-NATURAL-OUT
tobyS
840
IN
Thanks for the explanations.
I went and looked at a friends M939A2 wrecker and saw the PTO that comes off the rear, in line with the TC input. It uses a drive-shaft to turn a constant displacement pump.
Dave at Eastern has the PTO, but it breaks my budget. Go to my parts wanted page and you can see what it looks like.
How about a deuce transfer case or a lighter truck manual tranny, driven off the M931 TC to be used as a PTO?
Ron, if you happen to have a picture or drawing of the power divider, would you post one?
tobyS
840
IN
How about a small pony motor and hyd pump. Sounds like alot of work to reconfigure the trucks drivetrain.
I think you're right Will. I bid on one of the self contained 4 cylinder units a while back but they got expensive. I bid on some generators for the engine but never got serious. It just seems a waste to have such a nice power plant that will sit most of the time unused but hooked up, when I need the HP for saw(s).
tobyS
840
IN
Someone has to have something laying around. One of the single cyl engines from an older 3kw gen might work.
Yes, one is offered at a lower price on PM. Your post made me think about my use as the auxiliary power source and also having a primary saw power source that is independent. I think the truck may be enough for all my needs if the TC PTO can handle 50-70 hp.
I will mull it over as I work on the frame. If I can make it the only power source, it might make sense. Thanks.
I got a lot of (5) fifth wheel plates and trunions for a proper hitch to the tractor. Pick them up Wednesday at Columbus.
