Brake light switch question 1123
Thumper580
210
Virginia
My first truck was a 998. Had to move the brake light switch a little to get the brake lights to work. On my 1123 the brake lights are not coming on so I checked out the switch. When you push the brake pedal the switch lever maybe moves a 1/16".... Couldn't see where or how the adjust it for more movement/throw... Any suggestions would be appreciated. Thanks.
SmartDrug
306
Saint Charles, IL
It’s an ancient design that should have been changed decades ago. You have two switches linked together- brake lights and torque converter unlock. I’ve found that with a handful of zip-ties holding the zig-zag tight, I can make it about 6 months before I need to replace/inspect whether or not the brake lights are working.
I’ll grab pics when the kids go down tonight.
SmartDrug
306
Saint Charles, IL
With some pressure on the zip-ties holding the unit together, it’s perfectly reliable until the plastic begins to age out. I would love a more reliable setup as I will occasionally realize one of the zip-ties broke and unless I’m really laying into the pedal, I’m not showing brake lights.
Coug
4,589
Olympia/WA
mine I just used a large pair of pliers and bent the "Z" rod until the lights worked properly.
Coug
4,589
Olympia/WA
If you loosen the switch mounting bolts can the switch be moved rearward to preload the lever arm a little??
That's how it's supposed to be adjusted; loosen switch mount bolts and slide the switch one way or the other. The holes for the mounting bolts should be more like slots in which you slide the switch to adjust it.
I was along side the road during a convoy stop (we did a non-air brake vehicles run a couple years back) and didn't have the tools to slide it, just some pliers, which is how I figured out just bending the rod also works.
Coonass77
181
33
North Carolina
Not sure if it's just my bad luck or something more systemic, but I've had 2 m1123's that I wasn't able to adjust the switch (including bending the Z-bar) to a position where both the brake light and TC lockup switch would both activate when pressing the pedal. Both were solved by putting a couple washers on one side of the switch, between the switch and mounting bracket on the truck. The washers pitched the switch forward, thus moving the trip points more into the adjustment range of the switch. Once I did that, I was able to adjust the switch to a position that worked and haven't had to readjust either truck for 2+ years now. Not sure if this helps anyone, but just FYI if you can't seem to find the adjustment sweet spot.
nairb
110
33
Liberty Hill, TX
Could you post some pics of your set up? I'm having the same issue.
papakb
1,194
San Jose, Ca
The standard brake lights draw some real power when you step on them and the switch arcs internally wearing the contacts down to the point where you have to adjust the switch position to get them to work. Because the original design is marginal and there's no free play travel adjustment on the linkage the brakes can start coming on before the switch travels enough to turn on the lights so you end up standing on your nose before the lights light. Change the switch and then change the brake lights to LEDs. They draw so little power your new switch should last forever.
