Changing Out Head Studs and Nuts?
dabtl
Denton, Texas
I am putting new head gaskets on next week. I got the entire engine gasket set from OD Iron just in case we find other items that need work.
So, an old time mechanic tells me that it would be a good idea to replace the head studs and nuts. He says this is common in rebuilding diesel motors on heavy trucks. Has anyone here done this? If so, where do you find a source for head studs and nuts?
Westech
CPL
6,104
211
cow farts, Wisconsin
there not stretch bolts. you do not need to replace them. If you are doing headgaskets more then once I am betting you did NOT have the heads shaved and the valves reset in the head. Just replacing gaskets is not the way to do it, they will leak again.
WillWagner
3,151
Monrovia, Ca.
The only time a headbolt gets replaced is if there is pittimg in the fillet, the shank is heavily erroded or it is stretched past it's limit. The studs are very robust on the multi and they are a low torque item.
As for shaving them, get a sanding block and clean the face...don't polish it, just clean it. If there are any grooves in the face of it, most importantly at the fire ring area, that you can catch a fingernail on, it t will need surfacing. You can check warp yourself. Get a straight edge and check crossways on the face. IIRC, you are allowed .003 warp.
If both checks are good, put them back on.
dabtl
Denton, Texas
The engine was rebuilt in 1991 at Toule. I have never changed the head gaskets on this truck.
It will be resurfaced and the valves checked and fixed if need be before reassembly.
