CTIS switching to different programs?
Skyhawk13205
289
Alaska
GeneralDisorder did a post about the pin program settings on the CTIS controller. That is prob where you got that pic from. I have not read through it, but is makes sense, program the ranges into a controller from factory, set the pin program for each truck type, so you can swap controllers between trucks without having to reprogram.
aw113sgte
1,331
La Crosse, WI
All I have read was theory. Im sure that is exactly how it works on the newer MTVR ctis controllers with mode settings for weights.
I was reading the mtvr manual and it stated the mode button didn't change anything on mk23 variants. I think it had a function on ones with a PTO however?
Maybe that changed later?
DeMilitarized
1,076
Gainesville, GA
The weight settings on the controller are the only difference between m939 and mtvr controllers button wise
