CUCV and EMP
SDF Troop
Toney, Alabama
I'm working on a paper about Electromagnetic Pulse (EMP). Just out of curiousity, does anyone know if the M1009 is hardened against EMP? I know that most vehicles made after 1972 (or anything with an electronic ignition system) is subject to EMP effect unless it is hardened. How do you go about protecting any vehicle against EMP? Are Dueces EMP resistant? I wasn't sure if the military did that as a normal procedure.
Michael
39
Fulton, MS
Did you read the two posts that are recommended at the bottom? One of them has practically the same title. It is closed so I guess you couldn't add to it.
The CUCV is not shielded but it is debatable if there is much on it that needs to be. There are some good links in the old post.
Michael
39
Fulton, MS
I have picked up an item or two over the years that said it was hardened against EMP in the online description of the NSN. It was a wiring harness with heavy wire braiding around the outside like coax cable and screw on connectors at each end. Another was a wire in a metal tube with screw on connectors.
CUCVs just have off the shelf parts so there is nothing hardened about it.
