CUCV Vacuum Regulator Valve
Warthog
241
OKC, OK
You might even find one on fleabay or amazon
1,191
Or simply google the part number or NSN.
rsh4364
15
greensprings ,ohio
I recently installed one,nos off e lay,45$,There seems to be 2 adjustable points on it,one adj. is whole body.other is small round sect. in center of unit,any advice?
stationjj
Middle Tennessee
Checking Flea Bay for the $45 NOS part. As with everything it depends on how you search for it.
FYI use search 'AC DELCO CHEVY VACUUM VALVE TRANSMISSION 14057219'
This should find it better. Using the part number alone doesn't work well. It will show you other expensive options.
Good luck,
John
