Deuce winch tension channels
7mmTCU
Brooksville, FL
Would anyone have and be willing to share a drawing of the proper dimensions and the locations and size of the holes. Mine are pretty bent up and I dont know if after I bend them back into shape is they may have stretched a bit. I am thinking about having a set folded up at a local shop and finishing the holes myself.
Dean
tm america
25
merrillville in
The plates on the top ,back and the threaded rod on the bottom are there to keep the winch ends properly spaced.the main purpose is to keep ther from spreading on a side pull that would force the frame rails apart.2.5ton trucks don't have tensioners like five tons do.some five tons even have level winders...
7mmTCU
Brooksville, FL
I'm thinking this piece. Someone had them for sale in the classified section at one time.
Correct. One on top and the other on the back toward the radiator. Yes, ODIron had some reproductions but they are sold out. There is a past thread on it in the archive. I want to have a set folded up at a local shop. I'll finish the holes myself.
