dmetalmiki
- 2,034
- 113
- London England
......four years of, change this that n't t'other bleed, pump, kick, swear!, tweek, filter changes, test, re-pipe....and more...
So...,
Last Saturday I told the guys I was (Finaly going to replace the Hydraulic Heads on two non running deuces.
"You need a hand?"...Definately sez I.., Would you (All) just lift the bonnet (Hood) for me please?... (And) Yell when you see a red mark appear,
"Oh Oh".." here he goes again"...(They have a stop watch...)
Loosen injector pipes at the injectors and remove all clamping.
remove injector pipes from the Hydraulic Head,
Disconnect fuel flow piping.
Remove fuel control cover and throttle control parts,
zip off the the four retaing nuts and spacers.
'pop' under the truck and turn the engine via the propshaft,
"STOP". ..., (Yell).."Bit More".. OK! "bang on",
Back to the Hydraulic Head, Lift, And it comes right out.
"F.........'Eck"..comes a retort..48 & a 1/2 minutes! "OKPass me the new Unit please".....
refite in the exact reverse order.
"WOW!".....51 & a 1/2 minutes,
Jump in the truck (There are TWO CO2 fire extinguishers at the ready!),
Let the in tank pump run for 1 minute..,
Run the Engine Pre Heater for 15 seconds.,Wait.
Hit the Engine Pre Heater for 3 seconds, Then,
Push the starter Button with the pre heater running, For 3 seconds.
Repeat,..
The truck fired right up, Ran great!.
Runs and drives great.
So, A big, B I G Thank you to USAFSS-ColdWarrior for supplying us with Three Hydraulic Heads Copmplete with the Buttons and clips.
Just a hint for others doing this.
( I allways ), REMOVE the CLIP. (And), Bend the tangs SLIGHTLY inwards so that they Grab the assembly tighter.
The other Deuce was done in the same manner,..In, 48 Minutes, Including a Cuppa'.
Just the M54A2 Camper to do...It is dissmantled in just the same order, (And Is)... Just waitng for some more seals for the Head to arrive.
Beeerz' Time.
So...,
Repeat,..
Beeerz' Time.
