differences between M51A2 and M817
Robo McDuff
In memorial Ron - 73M819
1,611
Czech Republic
Do they have the same chassis?
Checking the manual, I found a few differences. The 817 is about 2000 lbs heavier, does that all comes down to the heavier engine?
The 817 does not differentiate between off-road and highway, restricting everything to a 10,000 lbs max load, whereas the M51A2 has a 20,000 max. The same goes for the max towed weight. Seems a disadvantage for the 817.
1,161
The chassis is longer on an M809 series truck to accommodate the longer engine. This is why you can't put the NHC250 in an earlier M39 series truck.
Don't know about the weight issues.
Robo McDuff
1,611
Czech Republic
The operator manuals say that both are possible in the 176 inch wheelbase for the dump trucks
M813A1
OKC, Oklahoma
All the parts should interchange except for the Engine, Hood , Front fenders and Front panels. The chassis and the running gear
are all the same and will interchange to include the Transfer Case, Axles, Fuel tanks, Cab and Dump Bed Assy
Robo McDuff
1,611
Czech Republic
That's good to know.
