Differences in Front Brake Rotors (Single Rear Wheel trucks vs Dual Rear Wheel Trucks)
UNIMOG-GUY
35
Blacksburg, VA/Denver, CO
Hey guys looking for some help/advice….
I did multiple searches with different key words and phrases and didn‘t find what I was looking for...
Does anyone know if there is any additional braking performance advantage in using:
https://www.autozone.com/brakes-and...or/p/duralast-disc-brake-rotor-5564/48875_0_0
This part is for a K30 w/ dual rear wheels.
VS
This part is for a K30 w/ single rear wheels
I have a 1986 M1028A2 w/ single rear wheels.
My question is does anyone know if the part# 5564 for the dual rear wheel trucks will fit the single rear wheel truck?
It‘s dimensions are larger which I would think would help with braking performance due it‘s larger size and additional heat distribution of brake cooling on a larger surface.
gringeltaube
Staff Member
2,682
Montevideo/Uruguay
The OD is exactly the same for both (12-7/8"), so the actual contact surface would be identical, too. Only thing different (as if 0.4 mm made any difference....?) is the total "height": 77.8 mm vs. 78.2mm.
