Differential
Unimog66
Entrelacs, Canada
I have a m1084 and was wondering if the middle differential is supposed to be hot where you can’t touch it . The oil is good. Are these trucks ok to do some highway ?
Ronmar
7,991
Port angeles wa
If I can hold my hand on it for 5 seconds, that is around 150F. Shouldn’t be much hotter than that… is it hot in the middle or out on the end of the hubs.
heat is a factor of friction/load. Are the brakes dragging?
Unimog66
Entrelacs, Canada
the whole thing is hot , the other 2 I can put my hand on them but not that one. The brakes are ok
aw113sgte
1,331
La Crosse, WI
You said back, but that's the middle differential. I haven't noticed a temp difference and have looked with a thermal camera. The middle differential does have some extra components and maybe it would be hotter if having to work harder to match the torque split (different tire inflation?)
Unimog66
Entrelacs, Canada
i will check the tire inflation. If I make a camper out of it do you think they are good trucks for highway use ?
Ronmar
7,991
Port angeles wa
it isn’t possibly locked is it? If it were locked, like the center diff in an AWD when you go into mode, if would cause a lot of gear loading on a hard surface, do not use mode/4wd on hard surfaces…
when you select mode the TCU powers a air solenoid valve under the passenger dash next to the fan solenoid, to send air to lockup that power divider axle diff. When you de-select mode, this solenoid valve should vent that lockup air. If that valve were leaking, that would apply air and keep that power divider locked Which would explain the heat/load as a locked divider would not allow any escape of torque due to wheel rpm differences…
Test 1: disconnect the air line to the power divider axle. Any air come out of it? shouldn’t be any when not in mode.
Test 2; jack up a rear wheel. If the power divider isn’t locked, and you start the truck and put it in gear, like any open differential, all the torque should be able to escape thru that raised wheel. Same thing happens if you drive the truck over a steep hump, you will loose thrust when an axle lifts off.
If the lifted wheel doesn’t start spinning and the other grounded wheels try to pull the truck off the jack, the power divider is locked…
GeneralDisorder
5,822
Portland, OR
It's on the back. The level is filled till it flows out the fill plug. Drain is on the bottom.... How did you check that is has oil if you don't know where the fill plug is :rolleyes:
